Seem everyone so far has something good to say .! Well my friend put on in his car three core & it want cool at all period he has tried everything.!
A new radiator of sufficient size is NOT the answer alone. IF the car is cooling well at highway or normal driving speeds,the rad is doing it's job. If not cooling in traffic,the rad is not getting enough airflow to cool.(this is taken un consideration a head gasket or cracked cylinder is not the issue causing heat problems) A proper fan and shroud are the two other most important parts. I had an aluminum rad, and a 6 blade fan...with shroud and it didn't work in traffic or idling. I installed a 7 blade steel clutch fan with shroud and champion rad and it cools very well.
I have used 3 champion radiators and feel they are exceelent value..best bang for the buck.
