OK OK i did not mean turn it off!!! you push the start button and hold it down until the lights come on the dash then you let go. I know. It does not work. I am going to hook up a switch to that fuse and just flip it off. Next time I hope that I have an extra 10 grand and can afford an srt8, Problem solved.
Too the best of my knowledge you can't do it by just pressing the button. You need to actually pop the button out and use the key to do the key trick.
Ryan
I also believe you have to pop out the push start and use the fob itself like a key for this to work. Worth a shot anyway, the push button pops out with just a fingernail (then goes flying! lol ask me how I know? really... don't ask me...) Good luck man!
