Re: how to get 3 temp sensors in a bb water pump housing?
[Re: DirectSubjection]
#110432
08/26/08 09:04 AM
08/26/08 09:04 AM
Posts: 3,336 Summit, NJ
whiplash
Summit, NJ
If you used the CSR water neck, you could weld an aluminum bung on top for one I think. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
I have the Meziere one on my 383 but its not flat on top.
But then the temp will be inaccurate until the stat opens fully?
If I have to do that, I'd rather tap into the heater core inlet fitting off the water pump with a T
- 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
- 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
- NEW BEST ET - 12.40@110mph...
