Like said, bypass the ballast completely, I run a 10* jumper wire.
as stated, ballast is not required with multi-spark, the coil never has time to heat up enough. to relieve future problems take it totally out of the eguation. alot of guys who want to retain a somewhat stock look dig out the filler in the back of the ballast an run a #10 wire jumper from terminal to terminal.
