Also, if not done already, run a heavy red wire from your alternator, directly to your starter relay, or where your MSD 12 v is placed. It not only will ensure high voltage to your MSD, it will not push all the voltage through your firewall stock wiring. You probably have already done this. Just wanted to mention it. Good luck
http://www.bing.com/images/search?q=msd+...amp;FORM=IDFRIR
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
