Re: blower gear oil/lube
[Re: Clanton]
#1098785
10/23/11 09:19 PM
10/23/11 09:19 PM
Posts: 18,157 Mass
DAYCLONA
Mass
do you have a pressure relief button on the ft case?i do not add oil to the rear, do you have a pic of what you have?
No relief button, should I use one? will the pressure be that much in the front cover?...this is the type of blower case, plate. cover that I have, also have the same "smooth" style bearing plate in the rear, with sealed bearings, seals, and 3 bolt retainer plates holding the bearings in, I have a cast finned cover sealing the rear bearing plate, I know I could possibly eliminate the rear plate, and use the rear cast finned BDS plate to mount the rear bearings, but if I decide to use the factory end plate along with the BDS finned rear plate, I don't need fluid/oil in the rear bearing assy?
Thanks for any input Mike
