Quote: Dyers? BDS? Who has experience with a street setup? What have you used and how did it go--who likes what? I have a customer and he is bent on a dual 4 carbed blower setup for the street. I have the 500 inch Mega block almost ready and am about to order the top kit--I have one pal that swears by Dyers--others say BDS--what have ya'll used and who has the best service.?? Thanks Moparts Gang!
If you're looking for big power, the screw is the way to go. For the street, the bottom cut should be in the 5lb range for pumpgas use, then use the pulleys to set the final boost pressure at the desired rpm......mine is cut for 12lbs and is driven to hit 20lbs at 8000rpm which is way overkill for driving around town.
