push rod oiling, jesel rockers and comp 892 lifters. The push rods have restrictors and one side of the lifter is blocked off.
With my W-5 I just finished up I run TD rockers with
PR oiling and the lifters have a axle feed on the lifters
also and when I was priming it, it had 65# when it
was spinning pretty good and 50# when the drill was
spinning about 300 rpm which would be 600 rpm at the
crank.. this was with 10W30 oil
