My new 582 B1 motor only runs 50# and never changes from idle to full throttle. I run a milodon dual line system with milodons pro pump. We run 20-50 Bran Penn oil. How much oil pressure is realy needed under full race conditions.
Seems strange it doesnt pick up pressure as the revs
goes up...might want to check the by-pass... specially
with that thick of oil.... change the filter also...
this is of course that the gauge is working correctly
