Quote: After having the car out of the trailer and starting to clean it up I will say the system did it's job and did it well.
It was an oil and alcohol fire it was out for the most part,then started up again. We are going to add 2 to 3 more nozzels under the hood with the system we are using you can run 6. We have what the rules call for which is 3. The plan will be to add at a min 2 at the fire wall in the engine compartment.
I am happy with the way it functioned, driver came out okay and most of the car is in good shape. Looking at the pictures you can see it never burned the paint on all of tubing.
