4.375" bore 4.5" stroke. I guess most others prefer the opposite to get to 540ci but mine works pretty well.
Thax. I was wonder if a 2.25 valve will clear a 4.375 bore.I'm planing on having some head work did in the near future so i can have the 2.25 intake installed
I run the 2.25" intake valve in my 440-1 heads on a 4.375" bore also. I recommend checking the valve reliefs in the pistons carefully to clear the larger dia.
