2nd gear used to pop out on mine as well. I put a new 2nd gear in it and it solved the problem. Also, mine used to shift hard. Make sure the transmission tight against the bell housing. The bolts have a tendency to loosen. Put some thread lock on them and that should solve your problem.
05 Dodge ram 1500 daytona 03 Dodge Durango 98 Chrysler Sebring 71 Dodge Super Bee 70 Plymouth Duster
