THANK YOU GUYS FOR THE INFO. I REALLY APPRECIATE IT.
I will check into how freely the motor turns, and then getting it apart, then seeing who has one if I still need one.
I wouldn't have thought 2 of the motor bolts also held it to the housing. I believe it would be the bolts at 12 and 6 position as I think there are recesses in the backside at the 3 and 9 positions.
AGAIN THANKS GUYS.
and Big Dod If all else fails I will do as you say and get the BFH out after it. Ha ha
Thanks David
