I have 2 pumps and the motor went bad on the one on my car.
My housing is modified and I want to just change the motor part from 1 pump to the other. I have tried to cut the gasket, tap a putty knife in between, tap on it with a plastic hammer and it won't move or break loose.
I don't want to damage the housing taking it apart so what does anyone do to get them apart??
I assume these are replaceable pumps, correct??
Mine keeps blowing fuses so I believe the pump is tying up or something like that. The wiring is all GOOD with no shorts.
Who do you go thru to get a replacement pump??? or do you send it back to meziere???
Please Help as I need to get this done asap.
Thanks David
