Quote: Just a word for you guys.... if you see a tanker truck in the station dumping fuel.... pass on your fill up for a hour or so.... as he is dumping fuel in the tanks he is stirring up the water at the bottom(ALL of the tanks have water in them)... let it settle out then you can fill
Not true since ethanol's introduction. Keeps water out in big tanks just like little tanks.
I don't get that one?? Ethanol is hygroscopic and phase separation is a huge problem in marine apps.
