Ok, let me ask this. Anyone running M/T 31 x 10.5 W with a 10 or 12 inch wheel just with mini tubs? Did you have to cut the outside wheel tub (closest to quarter panel skin)?
Yes I run a 63 with the 31x10.5W and a mini tub. On mine I have a 5.5 bs rim and use spacers and the inside tire rubs. I will change to a 4.5bs rim and they will fit inside and out with no issues using a 10" rim.
Russ
