Smokinwoody (Jeff) if you look at the panel I built you will see that they have different color lenses and rockers for that style switch. It makes it easier to tell whats on with out having to read the labels. The rockers are easy to change with a cheap tool that pops the rocker off from the front without having to remove the switch body. I have used these rocker switches for at least 15 years. They are avalible through Waytek wire if you are interested.
looks great...I may do the same when I get back on my 63 Dodge project...thanks
