That part I know .Was wondering if you can weld Cm to MS or the stock sheet metal
Yes you can weld CM to mild... at that point it has to
be tigged just like its CM... you use the same rod
Yes...but is it legal with NHRA?
That I cant say for FACT but I cant see why not IF
the mild meets the spec and so does the CM... people
add to their roll bars all the time
Thax. Mr.P Body I've always wonder that as I'm planing adding to my cage and thought about adding cm to the ms to hopefully save a little weight in the process.......
