I have these "blue" non-stick versions that work well. Don't recall if they are Holley brand or from someone else.
Double check EVERYTHING else. There are a lot of places and reasons for a Holley to leak, not necessarily from the spot you think - debris/old gasket between sealing surfaces, bad bowl screw gaskets, bad inlet fitting gasket or loose.
