well i swapped the plugs and it cold started better. after 15 mins of idle time it cut off and wouldn't start. Quick black of carb gumout and it started. Spitted, sputtered and backfired all the way around the neighborhood and almost stalled at every stop sign. At this point the car was finally running around 175-185 degrees. after 10 laps around the hood it had less issues so I took it out to the main road and ran it through the gears. Backfired like a mothertrucker. Pulled into driveway and put it into park car no idles at 1400 rpms not 850.
