Mal, you wanted the best shift,you got a manual VB.drive it like a manual. harden up princess
Tex
PS : it won't make you faster just more consistant
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
