my first post says 780cfm
Yep 780 cfm.
To the original poster, If that carb is indeed from a factory 302 camaro I would look into its value, Now if its a dealer replacement it won't be worth near as much, but a true original might be. If it is & its worth some coin i wouldn't run it, just put it away but not in the garage, then just get another carb.
