my first post says 780cfm
Yep 780 cfm.
To the original poster, If that carb is indeed from a factory 302 camaro I would look into its value, Now if its a dealer replacement it won't be worth near as much, but a true original might be. If it is & its worth some coin i wouldn't run it, just put it away but not in the garage, then just get another carb.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
