OK, here is the car and engine. 71 GTX, 4070 with me. 472 Hemi, 727, 3500 stall, 4:10, 325-50-15(28" tall M/T Drag Radial). Fri morn, 350 DA, 6 AL., 50/50 93 octane and 110 octane, launch @ 2000.
.176- RT
1.612 --60'
4.526--330
6.940- 1/8
101.45- 1/8
9.040
10.811- 1/4
127.21
Fri 1.29 pm, same set-up, 1350 DA, launch @2000
.035
1.605
4.515
6.931
101.48
9.036
10.816
126.57
Same set up, 7 pm, hot track, stage @ 2500, added 1/2 gal 93 octane.
.286
1.570
4.482
6.921
100.29
9.043
10.838
125.39
OK, now , with the help of some Moparts buddies, we swapped to the 7AL and matching coil. All we had was a 7000 rpm chip.
![](/ubbthreads/images/graemlins/bawling.gif)
Added more 93 octane, and this was Sat morn.
.117
1.573
4.481
6.920
100.38
9.038
10.825
126.07
100 foot from the traps, I hit the rpm chip. Also, checked the plugs, dead white. We swapped in four - 93 jets into the APD- prepped Dominator replacing the 90's.
OK, added another 1/2 gal 93, so all the 110 was surely gone. Forgot to charge the battery, got to the lanes, car died, towed to get it jumped. By the time I re-ran, car was 180 already. I was flustered. Wasted run
-.015
1.650
4.603
7.058
99.77
9.194
10.993
125.49
I had 2 inches of 93 in the tank. I added 2 inches of 114. Last run, Kahn from Bob George Racing gave me a 7400 chip. THANK YOU !!
.214
1.595
4.520
6.950
100.77
9.064
10.852
126.01
It liked a little bit of race fuel. Timing is locked @ 35 deg. Plugs looked better after this pass.
To sum it up, My best runs were with the 6 box. I am keeping the 7 hooked up until Indy. Thenn I'll make some passes, then switch back to the 6. I think I was on a run with the 7 until I hit the chip. Then I think running the 93 octane played a part. More or less, I think using the 7, and jetting up would have netted me better passes.
![](http://img.photobucket.com/albums/v605/sunroofgtx/Hemi%20Time/IMG_1545.jpg)
![](http://img.photobucket.com/albums/v605/sunroofgtx/Hemi%20Time/IMG_9390.jpg)
