My on making this change, unless your needig a better ignition system, IE the current one is missing or not jumping the spark plug gap the car will not make a noticeable improvement I have seen improvements when switching boxes in starting and idle quality but not a better MPH or ET at the track until summer time when the air in the Los Angles basin would go in the toilet, IE SMOG wss so thick you could stir it
