nice
Sound like you want what I had. but yours will be better( easier).
I had 3225 lbs, Ported stage IV 2.14/1.81 lucky if they flowed over 285 or so. . 13.75 -1 tarantula manifold, 4780 carb..( 800 cfm
Lunati roller, 276/284 108 .690 w 1.5s. I used 1.6 harland sharps. 9" J type convertor,( 5200 stall. shifted at 7000 hit the stripe at 7500.
5.38s and 14x32s on 12" rim.
What is your cam?
