See if the tang on the bottom of the shaft & the rotor location phasing are the same in both dizzys. I would turn timing marks to 10BTDC #1 compression (15 if wild cam) & turn housing till vac adv is in it's general location w magnet lined up dead even w nearest tooth w the rotor at #1 cap terminal
