Got home from work, and figured I'd swap the bulb, and then the sockets from side to side if I could narrow the problem down. Tested everything one last time, and now everything works normally, without me doing anything! Typical electrical problem. Thanks for all the tips, I'll use them once the signals start acting wierd again.
