What rocker shaft stands are you using? I had that same problem with my engine when I switched from DC valve covers to Moroso covers. The DC covers are a little taller and cleared the blocks that hold my shafts in place. The Moroso covers bottomed out on the top of the stands. No matter what I did I had a leak. Finally I took the end stands off and ground them off to the profile of the cover. Then they fit.
