Just went through the same. I could not get the intake between the heads.
I wound up putting extra head gaskets on until I got the intake to fit. Once I knew the deck increase needed to make it fit, I calculated the intake cut.
So in my case, it took two extra gaskets .040 (each), .080 total to make it fit without a gasket. I took the .080 x 1.23 to get .0984 or basically .100. I wanted to use a .060 intake gasket, so by the math I needed .160 total-I decided to just go .150. Since the heads had been milled and the intake side had never been cut, I cut the intake side of the head .050, and then I cut the intake itself .100.
Everything fit perfectly with the gasket after the cut. All the bolts run in by hand.
