Short answer, take it back.... Nason is the low line Dupont product...
Take it back and spend a little more for the good stuff. I cheaped out when painting my 510 and now after 6 years its showing all sorts of marks in the finish. Mind you it is outdoors all year and not covered. This was there single stage enamel.
I do have to point out that BC/CC is more durable than single stage paint. Should have used a urethane additive, it helps a lot.
