YOu need to run it forly tight on the extension side as to not crush the tire. Then soften up the compression to keep it planted. Ladder bar cars tend to hit hard and need tight extension settings. What is the relationship of the bottom bar to the ground with the car ready to race? Is it level, slightly downhill, uphill??
