I do keep separate logs for each car although I have never entered any of the data into the dag. It is setup for each separate car and can record 4 separate log books.
I have the Tag Dyno Log installed on my lap top that I use for my runs and then the data recorder for the Jrs has software that you enter the run info into.
All these have an entry for DA yet none have anything for VP or WG's
I'm not sure at this point if I can go back and back enter all the runs and weather for each car into the TAG or if it has to be done at the time of the race.
If it has to be done at the time of the race that would be next to impossible given the pace that I have to keep to run my car and the 2 girls. Dad is pretty self sufficient and rarely needs my help but when something arises on that car I need to thrash there too.
In other words, I'm often just jotting down notes on the times slips and then inputting the data much later when I have time.
