I was shooting for 11.60's and ended up w/ 11.39 so far, My set-up isn't much more aggersive than yours. .030 over 11.2:1 440, h-beam rods ross pistons, ported stage VI heads, 582/588 comp cams solid roller, 1.5 H/S rockers, 1 3/4 headers, stock MP 6-pack, Turbo Action 3800 stall and 3.91's. Car runs great on the street pulls 7-8 lbs of vacuum at idle and managed about 12mpg on the way to and from the track. Your build should get you into the 11's
[IMG]http://i66.tinypic.com/pui5j.jpg[/IMG]
Coming soon!!!!
