...why do you want to remove it?
It's not that I want to remove it, I just wanted to know if the possibility exists that the car will perform as well if not better without the ballast resistor.
It absolutely will run better, it's questionable if you will notice though IMO. The MA blurb said it will run better. Burning up the ECU is the only consideration. Empirical evidence shows it won't.
