the more amperage output, the better. Amperes are not sourced by alt, if car demands doesn't require it. You can even have 200 amps if you want but if car sucks just 50, alt will source just 50.
You actually maybe have a 500 or more amps batt, and you don't burn anything with that... why? because thats not demanded by the car
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
