i have dot5 in 3 cars and never had any problem bleeding/soft pedal. maybe someone shook up the dot5 container befor adding it to the master cyl.? i`m not sure how this old wives tale got started. just like the thin wall cyl. block casting.
you cant bleed them as fast as dot 3 - with dot 5 if you push the pedal fast then the air will be introduced into the system, and then you will have to let it sit before a final bleed.
Otherwise just push the pedal slowly and it will not accept the air from the mc.
