Because of my limited knowledge, I am a bit confused. I thought ported vacuum was manifold vacuum because it screws into the manifold. So where does a "manifold vacuum" hose connect exactly? Also, what is the "can". I know of vacuum ports and vacuum amplifier on my MP 360/300hp crate motor. Where should my vacuum advance be connected? Idle is a little crappy right now. Thanks.
