the reason the vacuum drops on ported vacuum is that as the blades of the throttle are opened the air is moved to the center of the bore;away from the drilled hole in the wall of the bore.Have you ever noticed that in a fast moving river the water on the edge of the flow will be slower or even move backwards than the water in the middle of the river?
