Quote: The filter is on the subframe connector. The filter is pretty big and made to go after the pump and although I don't remember the make of it, I do remember the flow rate on it was really high.
I would try another filter between the cell and the pump. Your pump may not be strong enought to push the fuel through that filter. Also, because it's after the pump, you may have trash in the pump/lines(before the filter) hurting the flow.
