Strokerscamp I'm currently running an A-body 8 3/4 with moser axles. 15x10 welds
with 6.5 backspace. Current tires are 28x11.5 et drags. They fit very easily. I would like to run something a little bigger if possible. Something with a 12.5 tread width and 29 tall would fit. But my question is can I run a radial that tall or will it grow and hit my front fender lip at high speed.
Plus I don't really know all the drag radial size options. Thanks.
If you have 5/8" clearance they shouldnt hit... IF
necessary you can put a spacer plate in front of the
front spring hanger to space the axle back some...
dont get carried away with this unless you change
the drive shaft length
