Quote:looking at your pic,i am thinking that its an early holley with the mopar throttle lever.looks like the stock throttle cable and TP linkage would hook right up to it.it does not have the lower part of the arm to bolt the adaptor on with the 2 bolts which only leaves the hole for the throttle stud.and how do you like wrenching it onto the intake,gotta work all 4 nuts on the studs at the same time..no?
