like John said,its an early holley
that would be a holley 6210 model 4165
650cfm spredbore manual douple pumper
4160 is a squarebore carb
i have a 6210/4165 on the shelf and it has the chevy throttle lever and will use that adaptor you posted to hook up the stock TP linkage.
not sure how it will bolt to the early holley if it will at all,i dont see how
then its not gonna have the lower hole for the lokar cable,only puts the stock mopar throttle stud in the right spot for the throttle cable and linkage
