not sure if any of the BB heads use the separate stands
The BB heads until I think 1962 used stands.
1963 was the last year for the seperate BB rocker shaft stands, 1964 and later have the cast in pedestals. 1964 was the first year of the six bolt valve covers also
The old max wedge cars used rocker stands.
get the billet aluminum ones as someone pointed out
put the stands on the shafts next to the old stands and try to determine how much to cut down the cast old ones.
Looks like the set posted above are the max wedge stands
with a MP P/N
