To go absolutely the cheapest you could use a 10.95" pressure plate and disk with that wheel. It's a stroker, no need to rev it to the trees. But if you think you will, buy a SEMA spec wheel and be safe. And if you do don't go heavier than stock, your big engine doesn't need it.
R.
