Quote: This in mine! I thought they were suppose to be straight up. I also have a hole in front of the one I am using. Would I be better off in the front hole?
Yes it should have the top leaning forward... if you were to lift the body you shackle will run out of travel vs if the top was forward... also if its too far forward it will bottom out on the rear when the spring goes into compression/jounce... so more isnt necessarily better
