Thanks guys....I'm going to make a bushing for the top hole to fill it up....don't like the idea of just slamming a bolt in there....probably would be fine....but no big deal to make a bushing either
Rickster
If you have a production bell just use the correct stud. No need to fab any bushings.
Yep... its just a shouldered stud... screws into the
trans and uses a nut.... bolt on the bottom hole
