your supposed to center the starter,thats why the hole is bigger on the top.
I think if you check the top bolt hole is larger I have seen this due to the stud size in the trans case.
the correct position comes from the starter itself fitting into the case or adapter plate
home of the
Sox and Martin Hemi Duster
