Quote: what would a 340 30/over factory 3.31 stroke be 344cubes? 3100 barracuda with driver.been 6.84 et @98mph 1/8 mile/ with otb eheads/rpm air gap/750 carb/258*/268*@50 roller cam/kb pistons/10.0 compression/power glide trans.Bring the big block on with = parts and watch what happens.
I just pulled some time slips from june of 05 this was a very mild 440 build using the stock crank, stock rods,.030 over TRW pistons with 10.3 to 1 comp. with out of the box eddy heads and a mopar .590 solid flat tappet cam in a 69 valiant street car 3115 race weight set up for 1/4 went 6.739 @ 102.66 in 1/8. So there's a big block = parts so what would happen??
Thats a 727 VS a glide
68 dart stock stroke .030 440 pg eddy heads roller cam 6.32 @ 109 mph , april 2010 I have time slips, went to a 520 this yr
