Well I realized that regardless of the outcome of the air tests, I was pretty much boned, as I need to put it back together.I went ahead and did what I could, also air checked the apply pistons (OK) and adjusted the bands.Wish I knew about the higher psi before I gave in and reassembled without a definitive check...oh well!
I located an accumulator piston spring and put it in, and after a little cooler line rerouting, we will see if it's
A)better,
B)worse or
C)time for some JimBeam :-)
